- Fri Jun 17, 2016 8:32 am
#59162
2 thoughts: what plastic is it made of? If, as seems likely, it's ABS, then get some methyl ethyl ketone (off ebay) and some scrap ABS (bits of old fairing, lego bricks) and make a thick solution of ABS in MEK. Use that to fill the hole, let it set for a few days, then tap it. Or, better, get a plastic insert with a brass nut (ebay again) and use the MEK/ABS solution to stick it in place.
