- Thu Jan 28, 2016 1:23 pm
#54733
I don't think you need to worry about dwell; compare with - for example - a V8 which has to accommodate 8 lots of dwell in every distributor revolution, we will always have more than enough, so you can use any of several usual methods to set your timing just as before after points have been altered.
I have been experimenting with a makeshift manual a/r lever as outlined in my recent posts "Ignition timing,iron engine", I am certainly convinced that advance and retard on a bullet is even at best a vague compromise. It only alters under rev changes, but not load as a traditional vacuum assisted system does; so maybe a handlebar a/r lever to supplement the centrifugal system will be the solution. Hey, maybe I'll mark it "Early" and "Late" as Mr Royce did on his excellent motor cars!!
