- Fri Jun 10, 2016 12:50 pm
#58765
If the kit had been available when I went down the PCV rabbit hole, I too would have given the carb conversion serious consideration. I did look into it but only found systems involving swapping out the alternator and sensors etc etc then; too complicated. I found the (oem ecu) either on or off, all or nothing, stuttering of the injector amid a slow corner/tight bend to be disquieting (actually the ditch is more worrying), and although the PCV helps, the 0% and 2% columns of the Fuel Table are not mapped (default ECU values there, closed loop). It can be fixed, I am gradually fixing it, but it is a lot more complicated with laptop and tables of numbers doing your head in than playing with jets and needle tuning a carb. You can probably get more power and torque out of the injector but you may well make it run better with a carb. What you can't do with the carb kit is alter the ignition table like you can with the PCV.
