- Tue May 10, 2016 7:51 pm
#58052
Sorry - I misunderstood as if it won't start rather than running badly. However I still think you should look at the work you did on the barrel as a starting point regarding the valves, and the ignition timing can also be done static on the cam which as it is electronic just needs to point at the right place (and in all probability you didn't touch it). It's as if you're not getting fuel in, inlet shut or not opening at the right point.
