- Sat Apr 30, 2016 11:49 pm
#57614
Oh dear, it sounds like your bike's electrics are a bit of a disaster.
What I'm thinking is that someone purchased and fitted the later 4 wire stator without realising what had changed when the later AC headlight system was introduced.
Please will you check and see what type of handlebar controls you have, the Magura or the later Minda type? This is a clue, but it also matters in terms of headlight wiring.
Remember this. The 4 wire alternator runs in two electrically isolated halves. With the yellow wire unconnected and the orange wire grounded ONLY ONE HALF OF YOUR ALTERNATOR HAS BEEN CONNECTED, via the red and black leads to the Powerbox in your case. That means that with the headlights on, the operating half of your alternator is being overloaded, while the three coils that SHOULD be powering the headlamp separately are doing nothing!!!
The yellow wire is the supply to the headlamp and the main beam warning light, NOTHING ELSE. It feeds the headlight via a separate AC regulator. The orange wire is the return wire from the headlamp directly to the alternator, IT DOES NOT GO TO EARTH (the Minda switchgear is designed for this, the Magura isn't). Think of a modern domestic AC electrical appliance. It may have a three pin plug, but on many appliances with decent insulation, the earth pin on the plug is now just a plastic dummy. There are only two wires needed, brown (live) and blue (neutral). So comparing AC headlights with domestic appliances, the 12V yellow wire does the same job the 230V brown wire, and the 12V orange wire does the same job as the 230V blue wire.
If you don't have the correct switchgear or the AC regulator, then the Snidal conversion for the 4 wire alternator is the only way you will get it to work fully. This means ALL FOUR leads will need connecting to the AC side of the Powerbox, EITHER the red+orange alternator wires on one side and the black and yellow on the other, or the red+yellow on one side and black and orange on the other. Read and follow his instructions TO THE LETTER.
It would be very tempting to give up on the 4 wire alternator, buy a Lucas RM21 with just two wires and simply hook them up to the AC side of your Powerbox. Job done.
Phew!
Phew!
