- Fri Apr 29, 2016 4:59 pm
#57597
Plus one with Mark and Ric..
A simple test (though not conclusive) would be to see if the headlight stays at the same brightness from tickover to 2000rpm when directed against a wall..
Should get brighter with increased revs.
If it does then perhaps 6 mile trips is indeed not enough to keep the battery in trim.
Suggest if the bike is garaged at night you should invest in a digital/electronic battery charger like the Optimate 4.. Just open the tool box and plug it in to the permanent connection to the battery that comes with the charger..
Simply unplug and start the bike in the mornings..
