- Fri Apr 29, 2016 5:05 am
#57591
You need to check and confirm WHERE the oil is coming from?
Oil tank? Oil level in tank drops slowly...
Timing chest?
No apparent change in oil level from tank...
,br>
I is very rare for the joint between the crankcase to suddenly allow oil to pass from the tank into crankcase. The usual situation is that the pump disc needs reseating. ..
Inspect BOTH oil pump discs (feed & return) AND seats for any scoring...
Both working surfaces are supposed to be perfectly smooth; no scratches or scoring. Reface and lap accordingly
IF the oil is draining down out of the timing chest, (highly unlikely) is is possible, though a touch tricky, to remove and renew the Oil seal on the end of the crank shaft.
What ever the situation, DONT ride off, or rev the motor with a wet sump situation as high oil pressure in the rocker oil line can occur.
