- Mon Apr 11, 2016 5:47 pm
#57251
There's a manifold pressure sensor built into the throttle body.
This detects the air pressure between the throttle body and the inlet valve and will supply a reading to the ECU which along with the data from all the other sensors will provide the correct fuel and ignition settings the ECU has been preprogrammed to supply.
If there is an air leak between the sensor and the inlet valve - and on our bikes there are several places for potential leaks to occur, then unlike an engine fed by a carburettor which will run weak with an air leak, the EFI Enfield engine will run much richer and with retarded ignition as this additional air is seen by the ECU as an engine under heavy load.
Check all the joints in front of the throttle body between it and the cylinder head and also the MAP sensor connector itself (found on the air filter side of the bike) to rule out this a possible cause of your richness.
