- Sat Apr 09, 2016 2:32 pm
#56900
Right, I've been told so many " its suppose to be like this" on here and else where. Hitchcocks themselves had also said about the going to the positive side of the coil. An American friend, explained it depends on if the black and white wire has current ( live ) or not, and at what point it is live or not, otherwise it can damage wiring.
Going off what he said, I did the check with the volt meter. The tests I did earlier did not seem correct. So I went over them again. Trying to figure out, why I did not have repeatable results.
I have constantly been going over the tests, because they didn't seem correct. How could I get one set of tests with results with a different set of test results on second set of tests?
So I reconnected the red and white wire to the coil, then conducted the tests again with the black and white wire.
With the ignition key turned on, with the kill switch in the not kill position, there is no current in the black and white wire.
With the ignition key turned on, with the kill switch in the kill position, there is current in the black and white wire.
With the ignition key turned off, and the kill switch in the not kill position, there is no current in the black and white wire.
With the ignition key turned off, and the kill switch in the kill position, there is no current in the black and white wire.
My kill switch is acting as an on off switch, with the ignition on, and when the kill switch is switched on, its dumping the power to the positive terminal on the coil through the black and white wire. This seems correct to me, and it is correct according to what the American chap said.
