- Thu Mar 31, 2016 9:52 pm
#56692
Bertie,
I understand where you're coming from with the LED, as with its much lower power draw it would be less affected by power fluctuations at lower engine rpm. However, seeing as how we are in Bullet World, there are a couple of buts.
I have tried an LED headlamp bulb in my Electra-X and it seemed fine, but make sure you have one that isn't too bulky at the back, as some are, where it might foul the speedometer if you have the standard casquette headlamp. Also I don't think any LEDs would work on alternating current, you might have to replace the AC regulator with its own regulator rectifier or re-wire the alternator connections as per PeteF's comment.
