- Sun Mar 20, 2016 4:38 pm
#6059
do not know if this is normal , started the bike without choke.because it was sunny and warm bike stared but was dying so I had to give it choke, with my choke on the bike runs at just over , 2000 rpm I try to shove the choke in a bit to bring the revs down , but if I do it cuts out ok the engine is still cold but I think running at 2000rpm is a bit much, into gear and away choke now of, went a run for about 4 miles to Tesco. I turned the tickover screw. down to about 8 or 900 rpm it ticked away ok. I was in maybe 25 mins kicked the bike , it fired but once again , it struggled to keep firing I blipped the throttle and it just cut out, I had to screw the tickover screw back up to about 1000 rpm and away I went perhaps its me and the bike is not fully warmed up although I did hear popping in the exhaust on the overrun but then again the bike was still cold maybe I'm putting the choke of too early but its running just a bit over 2000rpm I will maybe try and reset the mixture I'm sure I had a stuck float yesterday there was petrol dripping out of the drain but ive not seen it since
