By Les
#6051
[center]Nice day for a trip to Bodiam Castle
[center]Image
[center]This picture is for Scalyback and other military people this pill box is in the castle grounds
[center]Image
[center]Simon if you click the image there are more pictures of the pill box in my bucket you can give us all the technical info on it
By Mickey
#56435
Thanks for letting me know you were going Les, I'd have loved an excuse to get out of the decorating! Booked on a balloon flight from Bodiam castle soon, long time since I've been there.
The Pioneer Run to Brighton is this Sunday, don't know if any club members are going? It's a long ride (from Dover) but if it's sunny I might blow the cobwebs away. Mick
By Les
#56437
Sorry Mick a bit of a last minute decision, I also have a membership card to get in with so I did not want to stress the Enfield mob with having to get there wallets out, now the weather is improving it will be easier to plan ahead will let you know next time, haven't quite made my mind up yet about Brighton so far
By Les
#56438
It looks like no sun for Sunday Mick, thick cloud and some rain you should miss the rain along the coast, I would probably cop the rain from my direction will keep an eye on the forecast over the next couple of days
By Scalyback
#56439
Certainly it looks like a type 28, with the additional infantry section to the right (small embrasure (window)).
Did you see the trains at Bodiam? I was a member for 16 or so years, and still have a fondness for the K&ESR.
By RocketRR
#56443
Know it very well my Mother still lives in Tenterden and my grandfather used to help on the trains. We had a few happy Santa express trips over the years and so on for my children. Happy days
By Scalyback
#56463
well, checking the database, it's a type 28A...
Location: Bodiam Castle, Bodiam - on the S side, between the car park and the castle moat.
Condition: Good
Description: Anti-tank gun emplacement, scheduled with the adjoining castle. 21/09/1975 Anti-tank gun emplacement, brick-shuttered. Rear entrance with shelter wall. Main gun embrasure faces due S. Ventilation holes above embrasures are channels run in the roof. [from plans and drawing made by J. Gerken].
06/02/1999 Two-chamber pillbox: N chamber to house gun to cover River Rother bridge crossing. S chamber to house 4 x machine gun positions. Access by ramp from NE corner. 01/1997 Gun emplacement clad entirely with brick. The entrance is too small for a wheeled anti-tank gun. It is protected by a retaining wall to an earth embankment behind and to the side. The distance between the retaining wall and the wall of the emplacement is a gap of no more than 18ins. Allowing access to the interior is a ramp of concrete leading downwards from the ground above and running along the back wall. At the end of the ramp is a shorter return wall, therefore a right-angled turn is needed to enter the emplacement after first stepping down. The plan is not the usual rectangular one, the corners having been angled. The embrasures are square rather than rectangular. Behind, yet central to the main embrasure, is a square pillar which is surmounted by a circular plate of metal. In the main compartment, along the right-hand wall and the rear one, there are two supports of brick or concrete which appear to be supports for a bench or firing step. On the left hand side is an internal dividing wall; a vent that joins two sides of the emplacement pierces the wall about shoulder height. The secondary compartment has 3 gun embrasures. In the ceiling at various points around the wall are holes approx.6ins square which cross the wall, then descend to exit through the outer skin of the wall forming air vents. Two appear in each wall.
31/03/1996 FW3/28A variant (brick-skinned) situated in grounds of Bodiam Castle, built on elevated ground overlooking river and railway. 7 embrasures, 1 large, 3 medium, 3 small. Wood shelves inside on medium embrasures. with PLAN
06/08/1995 Pentagonal pillbox, brick shuttered. 6pdr. embrasure in front wall covers minor road bridge over River Rother. LMG embrasures in other walls, and embrasure in attached blast wall at rear. Bad crack in one wall.
