- Fri Jan 22, 2016 4:07 pm
#54416
Thanks for the info Mark, now I know for sure I'm in for a real struggle.
Thanks also Vince, surprisingly so far I haven't put the nut back on to extend the reach of my puller...a good idea...I'll give it a go, its worth a try. If it still doesn't work with my existing pullers, I'm going to wait for another puller I've just ordered from Hong Kong....it has 2x tie bolts across the legs (diameter wise) which hopefully will stop them splaying outwards and slipping off the sprocket which always happens when the pressure is increased...Will come back with any results if successful on any attempts... Thanks again....Les
