- Tue Feb 16, 2016 1:48 pm
#5935
With many thanks to KC1961, who pointed out, on another post, that the horn goes 'hot' when the ignition gets turned on...
My GPS was otherwise wired diectly to the battery, which was unsatisfactory, and it could be turned on or off by a switch mounted on the battery box. It was a hasty fix last year and I never liked the set up.
I found the 'live' horn lead and rerouted the GPS wiring down the front of the frame. I clipped the horn lead, bared the wire and paired it with the GPS 'live' wire into a spade connector. I had to manufacture a connector for the earth side by using some thin steel plate, but thanks to a protruding bolt on the crank case where the horn is mounted, it was easily fitted and is held in place with an 8mm nut.
Pictures, speaking a thousand words...
It works a treat now, the GPS fires up on the ignition key and shuts down when the ignition is off.
I'm calling this a success.
I didn't buy the bike to add years to my remaining life. I bought it to add life to my remaining years.
Exile.
Find me (and Thumper) here: http://thumperdiaries.exilesplace.dk/#home
Exile.
