- Wed Feb 10, 2016 4:22 pm
#54982
At the risk of going off on a tangent - but that's what we do on this site!!
I want to put in a word for ACF50 - because I'm convinced that it is a first class product! ACF50 has some qualities other similar product seem not to have - at least not not in my experience.
ACF50 is ‘active’, it ‘creeps’ very successfully wherever moisture can find its way and between two binding components, i.e. a screw and its nut.
I've found it safe to use on all electrical contacts and components, batteries, wiring looms, switch gear and ignition systems - and anywhere on the bike – EXCEPT THE BRAKES!
It effectively prevents road grim and salt from sticking to the machine. A quick wash after a ride – even a ride with the bike white with salt – will clean off the salt and leave the paintwork and metal still protected. It lasts well – once a year application can be sufficient – although I use it more often than that.
Another big advantage is that it stops corrosion progressing – its effect is visible within days of application. It doesn’t remove corrosion but prevents it from developing further.
First class maintenance spray - it really works! As you can tell - I’m sold on the stuff!
