- Tue Jan 26, 2016 9:07 pm
#5882
Help Chaps!
I've made up a heat shield for the high level exhaust on the Trials Cub.
Trouble is, the heat conducts through the spacers and the shield gets almost as hot as the pipe given time. I've drilled holes in the plate but still it gets hot.
Anyone know of a material which will be strong enough for the job, stand the heat of the pipe, but not conduct the heat so much.
I used brass at first then realised this is probably about the worst material to use.
Classic C5 Euro 4 at the moment.
Also CBf250.
Also CBf250.
