- Tue Jan 26, 2016 5:54 pm
#54667
Nigel - I do apologise for carping on. However I must say the lighting is not the best place for pull more power off even if Chris does pro installations there and the pilot is easy to find. The lighting is fused at 10A and runs the headlamp and tail. The dip switch is make-before-break meaning both filaments come on before the other goes out. The lamp is 60/55W plus the 5W tail which can draw (5+60+55)/12= 10 amps, which is what the fuse is, plus all the little instrument and pilot lamps is another ~16 watts. It won't bust into flames but you might find yourself suddenly riding in darkness, prince of darkness stuff, scary. I doubt that will happen because the load of satnav+phone is trivial and the fuses slo-blow.
The 10A lighting fuse is already fully loaded.
There's no lack of power from the alternator, it probably could run a toaster and the battery can spin that engine round, no lack of power there. It's the fuses, they blow if and when you exceed their rated current. The signalling, that's brake, indicators and horn can draw 21+(2x10)+30 watts (my pair of horns eat 60W) = 71W so 6Amps on the 10A fuse so there's plenty of spare capacity (even with my twin Bosch horns) - if you like the socket on a switched supply, that's the front brake switch supply.
The red fuses are 10A, the blue main fuse is 15A & imo the main fuse can be safely upgraded to 20A (yellow) like other models have it.
I calculate everything on all at once, horn and flashing the headlamp whilst indicating at night etc etc, to be ~215 watts, that's close to 18 Amps so I'm trying to figure out what they were thinking of by fitting a 15A main fuse. The CSA of the wiring is well up to carrying max current.
I have now fitted the DIN outlet at the side of the speedo bracket inside the casquette, the mini-DIN/USB has just arrived and will peek out of the back of the casquette neatly whilst clearing the tank, now awaiting iPhone mount to unused mirror thread.
