Yebbut the Workshop Manual "royalenfieldhandleiding.dpf" (for C5, E5 and G5 dated 2009) states tyre pressure as Solo front 18si rear 28psi, Pillion front 20psi rear 30psi just the same as the Owner's manual.
Nor is this entirely dissimilar to other british bikes, in particular I remember the Bantam front was 16psi solo. Some old bikes had rim clamps to stop the tyre shifting on the rim and the tyres had 'grips' inside to stop the inner-tube shifting; on the new export bikes these are 'tubeless' tyres which presumably have their bead slot into a groove in the rim to stop them shifting.
Much is made of the 'contact patch' area, especially if racing, this is (proportional to) the gross wheel load [lbs] divided by the tyre pressure [psi], answer in square inches [lb/(lb/sq.in) = sq.in*lb/lb = sq.in]. This is how much rubber sticks you to the road.
Elsewhere in
http://www.hitchcocksmotorcycles.com/fo ... post_92860 ChrisD tells us that his 1996 Bullet 500 weighs just 65kg on the front wheel, 'cos he weighed his bikes
(thanks Chris) which means about double that is on the back wheel, but that is without the rider, I.E. the front tyre pressure should be a lot less than the rear.
Tyre makers tell us to use manufacturer's recommended pressures, by that they mean Royal Enfield.
