...and we thought it was all getting clearer!
What you **might** have there Count Johnny, if your half width hub is a Redditch original, is a 0BA thread (as found on original Smiths Chronometric speedo case mounting studs), the 6mm thread is a very close match, but if your hub is one of Indian origin, it could well just be 6mm! How old is new old stock in this case?
By jefrs
#53693
There you go :-) You could have M6 from the 60s or it could be 0BA which is also 'metric' made to nearest preferred inch-size. 0BA is approx 6mm O.D. with approx 1mm pitch so you may well get a 'Class B' fit of M6 to 0BA. The BA-series were originally for modelling at mm-to-inch ratios; I don't mean toys, it was quite often necessary to build scaled-down models of items before full scale, a job often handed over to apprentices. So BA taps and dies would have been very common in an engineering works. Did RE fitters and machinists own their own tools like they did at GEC? The thread size could depend on what the chap had in his tool box.
By Scalyback
#53699
See? You just had to bring Metric and BA sizes into it. That completes virtually the whole family.
Thanks Denis C, I will check and try to work out if 55 or 60 from the gauge which is whit, so 55?
Right! Anybody wish to a nylon or cotton thread to this debate as we seem to have all the rest!
By Scalyback
#53703
I already got the grease nipples, now I got to drill and tap the holes to put them in. Though it might be a bonus if I could use the same thread for both nipple and hole.
