- Thu Jul 30, 2015 8:04 am
#49953
In my experience none of the sealers currently on sale actually work for very long. You might be lucky and get a year of regular use. However, if you only use the bike occasionally and (this is really important) drain the tank completely if not using it, and then you may be ok for longer. None of the fuel additives on sale will stop the Ethanol attacking the tank, they are intended to stop ethanol mixture fuels destabilising when in storage (ie, gumming up and attracting water) so no relief there either. If you can find non-ethanol laced fuel you'll be fine, it is out there! One possibility is to go to your local airfield and buy aviation (105 octane) fuel, it's not cheap but a properly built GT goes really well on it, believe me!
