- Fri Dec 11, 2015 3:24 pm
#5768
I don't know if anyone else has had this problem but when I change the oil in my 2012 EFI Classic Bullet i am never able to get the full amount of oil (2.75ltr accordind to the manual) in. With the engine hot i undo the 2 drain plugs ( and open the filling plug so that there is no air block). I move the bike from side to side and wait until the last drop has tipped out while replacing the oil filter & then the two drain plugs after cleaning the metal filter & magnets. While filling the bike with new Motorex semi synthetic 15W/50 I can never get more than 2 litres in before the level is showng over fill & the window is completely full.
The same thing happened last year and i even had to drain some oil out to get the correct level back. What am I doing wrong? I have run the bike all summer with only 2litres in and the level showing full all the time. It has not dropped at all after 3000km. I can only imagine that there is "something" in the engine preventing the correct amount of oil in, or that the 2.75ltrs is not correct. The bike has been running perfectly for nearly 3 years in all sorts of weather, (including well below freezing), and I am completely satisfied with it apart from the worrying that it will soon seize up because it is running with almost 1litre less oil than is needed?
Ideas please, "nicklov" Helsinki, Finland.
