- Mon Jul 06, 2015 8:00 pm
#5282
Hi all fitted our hosts gearbox cover strengthener at the weekend, everything went well and found why the gearbox had been weeping slightly all the inner cover screws were loose allowing oil to weep into the outer cover space, one leak down one to sort. After fitting the strengthener and drilling out the front cover and fitting it back on I went to fit the neutral finder and found it wouldn't go in, after checking it out I found when the cover was tightened it was causing the cover to dish slightly. So removed cover and fitted two 6mm washers as spacers on the Allen bolt that fits through the cover into the strengthener this has solved the dishing problem,
Adjusted the clutch and took Becky for a 30 mile run everything felt a lot better just needs some fine tuning, however when looking at the outer cover it still flexes slightly but no where near as much as it did, you can also see the grease nipple move slightly, has anyone else experienced this or done any other mods to it.
Does anyone know where I can get the neoprene gasket that fits in the tappet cover our hosts don't see todo one.
