- Thu Nov 26, 2015 9:50 am
#52585
Hi Adrian. I fitted the powerbox as the regulator was goosed, and to buy a reg/rec pair from Hitchcocks was actually £1 dearer than the powerbox! Besides, the PO has fitted the Boyer electronic ignition, and if you read the instructions that come with the powerbox, apparently running without a battery is not a good idea. Having had a good poke around it would appear that the 2 marker lights and the sidelight are actually LED's which are connected to the rear lamp circuit, so will need DC. So, the plan is for today: 1, wire the sidelights/rearlight straight into an ignition live source. 2, break away the headlamp source and connect to the AC side. So, I won't have to worry about the main switch. I'm a big believer in headlamps 24/7, and am a bit of a sod for forgetting to turn them on if there is a switch (like my Triumph T300), so like a more modern bike I have lights all the time. Would my plan work in theory? Thanks, James
