- Wed Nov 04, 2015 5:23 pm
#5669
I'm wondering if I have a stretchy cable?
Every time I go near the bike it seems I have to adjust the clutch cable. It will only be by one flat of the nut.
By the time I finish the ride, I'll have to adjust the cable again.
This is the current Classic 500 EFi, 2015 reg, probably 2104 build. So I don't have the rod and ball adjuster as on earlier models, just the cable.
The small lever at the engine seems to be in the same place. It seems to me that I just have to keep taking up slack in the cable. I suspect the outer has become spongy, and whilst not stiff, it doesn't seem particularly free moving. The cable is original fit indian, we've done about 900 miles. The clutch switch does pull the cable back into the handlebar lever which takes up slack from the clutch end. I'm setting slack to a scant 3mm.
Does this sound normal?
Has anyone else had the same problem?
What is the solution?
