Having done a bit of polishing over the years i can only speak as i find..
Namely don’t use anything cheap or Chinese when it comes to things like abrasive wheels, grinders, anything that can fly apart or disintegrate in normal use..
Google, "Chinese Escalators" if you want proof of their engineering prowess..
150-250 watt motors are fine for 3†polishers, Jewellery and small items but for 6†wheels a minimum 370watts and 8†something in the region of 500watts may be just enough..
Its surprising how easy it is to stall the machine, even when applying moderate pressure polishing something like a gearbox outer cover, or primary cover with a six inch wheel.
Add to this the length of time in continuous use, Even a 500 watt motor will get fairly hot given a hours work and you may have to stop operations or risk burning out a lower rated motor..
In this case a good biggun will always beat a good littleun..
http://www.metalpolishingsupplies.co.uk ... ng-kits-1/
