By Gaffer64
#5593
Hi guys,
I have a RE classic (350) 2007. Please can anyone advise what the setting should be on air screw and mixture screw on the carb. I have the Small air screw set at one full turn from fully closed and the larger mixture screw set at four turns out from fully closed. The carb is the one that came with the bike.
Cheers
Mike
By Paul M H
#51518
If yours is the standard old type bullet with Micarb. See technical notes on left for more info on tuning the micarb. The large screw in the throttle stop Screw small is the air pilot screw. Short cut to notes below well worth reading just copy & paste if it works.
http://hitchcocks.sincordia.co.uk/pictu ... s_-_a4.pdf
