- Thu Sep 03, 2015 10:28 am
#5485
Hello All
I've finally taken delivery of my new Classic 500 Limited Edition Despatch. Having lurked on this site for a while before taking the plunge I get the impression that one needs to take care to protect the starter sprag clutch, inasmuch as this is possible. (Just like my Triumph Sprint then....) I had hoped, therefore, to start the engine using the kickstart. However, on my model there is a small guard pop-riveted onto the cover on the silencer. Unfortunately the kickstart pedal clonks this (technical expression) making it very difficult to kick start. In fact the the guard was already loose when I inspected it. I have taken the bike back to the dealer, who is fortunately within walking (pushing?) distance from my home. I had to collect a load of spares that came with the bike anyway. The dealer immediately offered to sort it by drilling out the rubbishy alloy rivets and replacing them with stainless nuts and bolts, which is what I would have done. The clearance is really minimal though, so he also suggested moving the kickstart out by 1mm. We agreed that this fettling work can wait until the first service.
In the meantime I am obliged to use the electric starter. This works well enough from cold, pulling the clutch lever and using the "choke" (I know how it works)and not touching the throttle. When warm, however, the engine seems to need a bit of throttle to start. Is this normal, or should it start with a closed throttle when warm? Or are they all different?
Re kick starting, is there a recommended procedure for this? There is no mention in the owners handbook, which was printed in 2008 and relates to the early Classic sans kickstart. I should perhaps mention that I can start big singles, having in the past owned a BSA B33, a DB32 Goldie, Norton 19S and Moto Guzzi Nuovo Falcone and started and ridden other singles such as a Velo Viper. All of these of course had a manual valve lifter. Any advice much appreciated.
The other question I have is, what exactly is the twin spark engine? Mine only has a single spark plug (which I've already changed for an Iridium one). Does RE actually manufacture a twin spark plug head, or is it only a mod that can be done, like on airhead Beemers? Just curious. Ta.
Alan
Sic se res habet: Fractum est.
Alan
