- Tue Sep 01, 2015 6:26 am
#5476
Guys: Has any one replaced the stering head race on a 2003 sixty five?
I don't know if the current set up fitted to this one is the origonal one or not, is a ball bearing type with the usual ball bearing / cup set up along with plastic dust covers on both top and bottom bearings (untill i took the yolks apart was unaware was a ball bearing set up i thought would have been a tapper roller set up (same as the new parts i got from HM) all the new components seem to be the wrong kit
The new set consists of two taper rollers with cups (so far -so good) and two, what seems to be over size cups (lower cup, outer dia would interfere with down tube (result in not fitting snug in the frame) also are too large to hold the taper roller bearings, there is also a third component which ain't sure where this fits. Can any one shed any light on this please. Or is it just the wrong part ? have you had same problem? did you keep with the ball bearing set up rather that taper roller set up?
Cheers
Guru
Cheers
Guru
