- Thu Aug 06, 2015 7:23 am
#50064
I have fitted these to a number of bikes I have worked on / restored. A BSA Starfire's owner wanted to run without a battery, while using a Boyer electronic ignition, a set up I have seen on numerous unit BSA singles [yes I know about low voltage, full advance, blah blah, but many start and work fine] but starting on this machine could be a pain and it stalled at idle if the lights were switched on, so I talked him in to having a battery and all was well after that. I also added a battery to a similarly equipped BSA B50 MX recently, as you need all the help you can get to start one of those! However, another machine, a Triumph Tiger Cub I restored retained the original points system, with no battery and this would fire up first kick every time and idle with the lights on, but they would brighten a little with some revs applied, as you would expect. I also noticed on this machine that after running and switching off, hours or even days later, I could press the horn button and get one very brief 'beep' from it, so there must be a capacitor of some sort in the powerbox. One thing you definitely DO need, is a good alternator to run without a battery and good wiring, whether you use a powerbox, zener diode, or whatever else. Cheers, Paul.
