- Sun Jul 12, 2015 2:02 pm
#49351
Unless you bought a very low amp-hour battery the charge should not drain away before your eyes. First check with the battery OFF the bike, charge it fully, leave for a couple of days then come back and try the headlight bulb across the terminals, if it lights up brightly the battery is fine, if not it's a dud battery.
Assuming the battery is OK, then you have problems elsewhere in the electrics. I don't know if your system is 6 volt or 12 volt, DC lighting only or the later version with AC headlights, but try isolating the regulator/rectifier from the frame or earth and see if the charge still holds up with the parking light on. If it does, then these components need replacing. Also check the wiring to the light switch in case there's anything wrong there. A wiring short circuit should just blow the fuse to the battery, but you never know. I once managed to wire both dipped and main headlight beams to come on at the same time on a bike, which drained the battery very quickly!
