- Wed Jul 01, 2015 11:17 am
#5264
[center]
I read in some internet blurb that Meteor Minor engines changed spark plug type after engine number 7027.
For that and previous engines, they took a Champion L7 later L82C, or a NGK B6HS
Engine number 7028 and onwards took a Champion N5 or N5C or Now Gone Kaput (NGK) B6ES.
Also I understand that usually, the engine and frame numbers match for original bike but mine don't. Of course, engines do get changed if they go bang, but here is the odd thing. I have the original R.F. 60 logbook, as the first tax license issued is for 15th Aug 1959, and the vehicle details have frame as 7777 and engine as 6229?
It also says that the vehicle was first registered 15th Aug 1959, so it seems it came with mis matching numbers? Did this sort of thing happen occasionally?
So... I go to check Kevin's secrets and find these...
Headstock, it says 'B' with 7 - 59 under it. Could that mean "Born July 1959" as it was registered Aug 1959? Then there is a raised bit that says 4759, with a triangle underneath. Is this the frame number a part number or something else please?
This is stamped on the front of the engine...
And this on the gearbox.
Are these the engine numbers?
P.S. I don't have the instruction manual yet, so cant look up where the number should be.
Scroll down to bottom of the page from link below to see logbook (and other great RE stuff)
Scaly's junk
Tabellarius de verbis ostensor gaudium
Scaly's junk
REOC 15084
Tabellarius de verbis. Ostensor gaudium
