By Lycan-Moon
#5234
Hi !
I am swapping the front mudguard on my 2001 500 classic Bullet to one from a 350 Bullet, and now find the front & rear 350 stays fit fine but the central stays are waaay off ! either the 500 ones are the wrong angle and too long or the 350 ones are slightly out on the angle and holes !! ??
Has anyone done a swap ? how did you find it ?? did you have the same problems ?? how did you get round it ? Any help would be very much appreciated , Thanx in advance ...
By Chris Tindal
#48753
From memory, I had the same problem with the middle stays, simply got some used ones off e bay. I'm sure our host could sell you a couple of replacements :-)
By Lycan-Moon
#48755
Thank you Chris ! I thought I was going mad !!! I will probably be able to either adapt or make some new ones with a bit of help from a friend , your help is very much appreciated ..All the best, Kev .
