By bmh67
#5201
How do I test the coil?
Should it be power on both sides of the coil?
Regards from Norway.
By Revband
#48562
If the points are open yes, if the points are closed no only on one terminal.
By Leon Novello
#48565
Power off. With meter set on 20 ohms,two probes on the primary terminals, should read 3 to 5 ohms. With meter set to 20 Kohms, one probe on primary terminal, other probe on high-tension terminal (the one that goes to the spark plug) should read around 10000 ohms,say between 9 and 14000 is good.
