- Sat Jun 13, 2015 6:06 am
#5177
Hi.I was wondering if anybody knew of a method for removing the inner collar of the timing side main bearing from the drive shaft on a bullet engine. I seem to remember having done it a while back, destroying the shim in the process. I've just fitted one by gently heating it and tapping it into place, only to realise that I'd forgotten to put a shim on first. I don't want to get heavy handed with it as it's a posh bearing and a very posh flywheel. Any ideas? Spech.
