- Mon May 18, 2015 7:33 pm
#5088
I have been running in my 350 Bullet and have done about 700 miles. I fitted the higher compression Indian piston from our hosts. When first put together the compression seemed low (as gauged by the feel of the kickstart lever),but it started and ran well. The bike is still running well but the compression seems poor and seems to leak away when the kickstart is pushed down.
European rings are listed in the Hitchcocks catalugue,would these help? Any experiences?
I fitted the piston and forgot to check the ring gaps as I should have done.
I am using budget 20/50 oil.
I would appreciate any comments on rings and running in. I was planning to put some more miles on the engine and then strip the top end to check the piston and rings.
