- Mon May 04, 2015 9:11 am
#5026
Hi Simon, I wanted to have a crack at the cork clutch that you talked about some time back.
I have the 5 plate conversion in my 2002es iron at the moment and it works well, never slips but its just the old problem of drag after the motors got hot.
Cannot reliably get neutral at a standstill and it tends to deter me from venturing into town traffic..
I can’t remember if you fitted the push through type plates with inserts, or the bonded type (if they are cork)..
I rang MrH and he had inserts but no plates to fit them in.. Can you remind me how many plates and what type are in yours at the moment.. I assume they will fit all the iron barrel clutch baskets even with cush drive clutch centres? Or do i assume wrong??
Grateful for your advice. Cheers gwilly..
