- Sat Apr 25, 2015 7:57 am
#47067
Simple solution - go back to a manual advance and retard like my AMC machines have! Then you can simply jiggle around as you ride until the engine sounds happy. As a matter of interest, the amount of advance that I use on my 650 AJS does vary a bit based upon where I fill up with petrol - so some makes of fuel do, I think, burn marginally faster than others. My 500 Bullet seems impervious to whatever cheap fuel I bung in, even when it goes a bit stale, so I suspect that absolute accuracy in setting the timing is not that critical. Might be different for tuned examples, but just my own view based on my own experience.
Either way, not worth getting hot and bothered about!!
