- Sat Apr 18, 2015 10:30 pm
#4928
Me again. The enfield newbie.
Picked my 535 up today! After 3 hrs and a very sore foot i got it started (flat battery haha)
Managed to set two car alarms off on the estate on the test run! Sounds lovely
Anyway ive removed the clocks, as in I have taken them apart and disconnected all the wires.
Obviously i need the ignition switch and the speedo cable is ready to insert in to new small single unit.
My question is regarding all the leftover wires, ie indicators, the three bulbs that were in the ignition box (neutral etc) and alll the wires that went to the rev counter and speedo.
Do i need to trace these back and just disconnect them , or could I even remove the bulbs and just tie them all up together and tuck away just incase i put the bike back to its original(ish) state?
When it comes to electrics I'm a total novice.
I just want front and rear light and ignition barrel, I have no idea if there would be any repercussions from hacking the wires to bits!
Appreciate your help guys, this message board is somewhat a bible for a new RE owner!
