- Mon Mar 30, 2015 10:02 pm
#4845
Hi all. My 2010 Electra efi lost all its electrics this morning as I set off for work. I've got it going again (blown fuse). Not sure why it blew, but suspect a short circuit. I've tidied up some of the wiring to deal with that, so fingers crossed. Anyway I didn't have a spare fuse, so I swapped a working fuse from one of the other of the 3 fuseholders next to the battery. The bike runs fine with just two of the three fuses in situ. Everything else works - lights horn indicators etc. so I'm wondering what the circuit with no fuse does. Im guessing that the fuse I replaced is for the 'run' circuit. According to the wiring diagram it looks like the fuse I removed might be something to do with the charging circuit as there are two other fuses in the battery and 'regulator/rectifier circuits. I guess that means that everything will work, but only until the battery goes flat. Am I on the right lines. The bike works without the third fused circuit connected and with it connected. I don't want to damage anything by running the bike if I shouldn't and I don't want to get stranded if the battery goes flat. Any advice would be much appreciated. Thanks. Martin
