By Scalyback
#45404
You could make a little notepad or wordpad file, with the code you use in it, then just copy and paste for text colour.
After a short while, the new paragraph
#45444
Scaly,
How are you posting that code without it doing it's job (if you see what I mean)
There must be something like brackets round it or something.
By Scalyback
#45513
What the heck?
how did you get a marquee scroll?
Now can you do that on a bulletin board?
By Scalyback
#45514
will have to space it out
& l t for open bracket, & g t for close brackets, with out spaces.
By Scalyback
#45515
You look near the bottom of the page of source code and can see how the codes work!
[center]Image
[center]Image
By wilf
#45517
Impressive stuff.I'm dazzled. Is this for real? How can mere mortals begin to understand these things?
By John L
#45518
Yes, amazing, dazzling, impressive - and any other superlatives you may care to use. Maybe someone can explain how any of this will help some poor sod sort problems with his Enfield......?...... Labor gratia laboris, Scaly?
By Scalyback
#45519
Cos we can lay out the answer better than just a block of text?
