- Sat Dec 27, 2014 11:15 am
#4531
Those who read my last post will be aware that I recently upgraded my oil pump to the high capacity version as well as replacing the drive spindle using the more expensive English version. A month down the track the bike develops a very nasty bottom end knock so I pull it apart to find that the new spindle has completely shit itself. I immediately contacted our hosts to ask them what they would do about a faulty part. Before they get back to me (they are no doubt groaning with excess Turkey and Ham somewhere at the moment) I swatted up assuming that the oil pressure relief valve has failed. Not so I discover there isn't one. Weirdly the bike doesn't have the lovely little sprung ball in the crank that my old 51 Bullet had it relies instead on the pump rotors being lifted off the body when the pressure is too great. A little cretinous but I suppose effective. I discover further that my predilection for straight 50 mineral oil is also a potential cause of issues as the cold viscosity can overload the pump too. I fire off a new email to Mr H and crew with a mea culpa and set about checking to see if its run the big end. Seems with the piston and barrel off to be ok so I put it all back together again with the old pump spindle. What do I find though the pump jams at one spot. On careful examination it seems that the big piston on the improved scavenger pump is hitting the web on only one side of the pump body. I pair off the offending web with a sharp chisel and round it goes. Still clearly my fault as I should have checked that the pump turned ut a trap for young players and one to be careful of it yo intend to upgrade to the high capacity pumps. Seasons Greetings all.
