- Fri Mar 06, 2015 8:46 am
#4733
I'm re-assembling my 2004 Bullet Sixty 5 after a strip-down 12 months ago. I did photograph the strip-down but there is an extra earthing wire about 300mm long that I can't figure out where it goes. There is only one thick earthing strap (green) from the battery negative to the bolt at the rear of the battery carrier, isn't there?(which I have in postion now). I think the extra earth wire (thin black wire with brass connectors) was also connected to the same point on the back of the battery carrier but I can't see where it's other end goes.
