- Sun Feb 22, 2015 7:27 am
#44548
For the bike to be puking oil from the breather there are several possible issues, but what breather is currently fitted and how is it plumbed?
Regards the Bunn breather, if still fitted remove it. The valves are very problematic and at times cause more problems that they are supposed to fix. Overpriced and Over rated. 'OK' while they work, junk when they dont...
Why did you disconnect the original breather off the drive side to the top of the oil tank?
That was intended as an alternate oil return to the oil tank...
Have you checked the breather valve inside the end of the crankshaft nut?
Is the vent pipe from off the top of the primary cover open?
The sump is not being cleared of oil fast enough, which usually implies a blockage in the return lines, which is common to find the oil ways obstructed with wee bits of shattered oil ring lodged inside them, only problem is you really do need to strip the cases to get at one particular oil way with LONG drill bit...
Next problem is dealing with the oil that is being forced out of the breather: you need to vent the oil tank better; Ala Mk1 Interceptor, with a vent off the oil tank and to the rear. You will also need the Inter Breather from the crank case to the oil tank with a Banjo fitting.
Part of the issue with oil return from the sump is from oil passing out of the cam shaft tunnels and into the sump, instead of running into the timing chest...
But fitting the larger return pump should have addressed that?
Have you lapped the new return pump disc into its seat?
Is the pump disc spring strong enough?
Has the RH exhaust tappet been removed/replaced? if so then MAYBE the oil drain from the exhaust cam tunnel is blocked and ALL the oil is heading to the sump via the cam tunnel windows and the oil holes in the bottom of the barrel?
IF the oil way from the sump up to the return pump is blocked, there is a 'dodge' that will bypass the internal drillings: by fitting an external oil line from the sump to the pump suction! But it is only a temp dodge, as the max size of the oil way is limited by the size of the threaded plug that seals off the end of the suction drilling...
