By jmb_ten
#4673
Hello Flea Friends,
Some time ago I inquired about the foot peg tube which I am having fabricated. Norm was kind enough to reply. He stated the foot peg tube to be 7 and 1 quarter inches long. I ordered a kickstand from Hitchocks and the distance between the mounts are 5 and 3 quarters inches. Should I just make my tube to that size or am I missing something? I don't think the kick stand would be attached before the tube is welded on. I was also able to get the original break lever. It appears that it just hangs there off the bracket and attaches to the break rod. I am using makeshift footrest arm assemblies off another bike. Trying to get a good photo from the underside to see how it all attaches. I am not sure if photos can send through this site. My email is [email protected] Hope it is OK with Hitchcocks to put my email on forum. Any help would be greatly appreciated.
Also, I am having difficulty coming up with the nut on the Crank shaft drive side gear. I ordered one from Hitchcocks but it is incorrect. Thin 7/16 x 26 tpi. It is a finer thread. Hithcocks said sometimes the used different threads on war era bikes. They thought it might be 7/16 x 20 tpi. I am in the US and have not been able to find anything that will work. Tried Whitworth and UNF. Any suggestions?
Thanks for all your help!
Jeff
#44398
Sorry Jeff can't help much now, the Flea I had is now up and running and registered and the owner has taken it away.I assume you are talking about the center stand and I'm pretty sure it fitted between the 2 frame rails on the bolt that holds the brake lever
By Scalyback
#44440
Thanks! I had forgotten about thread gauges, and will order one. I sorted out all my BA taps in order, and found a 5BA ! never seen one before.
By jmb_ten
#44504
Norm and Papa Smurf,
Thanks for the response! i will order a thread measurement tool from your source.
Jeff
