- Fri Feb 13, 2015 1:19 pm
#4664
Hi,
I am having trouble removing both fork springs, I have removed the main tube valve port the spring strut is out but the springs will not pull down I have gripped the end of the coils with mole grips and even tried drifting them out down through the top with filler plug out. Are they attached to the large top allen headed bolt? I have followed our hosts instructions that came with the softer springs up to the point were it says "the springs should now fall out" maybe it needs a more aggresive approach!
Any help appreciated.
Regards Roy
Regards Roy
