#4633
Hi Everyone!
Scottie here from Denver, Colorado USA. I just wanted to share my bike build that I've been working on for the last few months. This is my 1958 RE Indian Trailblazer, it is punched +.040 over, converted to a Thorspark electronic ignition, primary chain drive converted to a dry set up, a custom 2-1 exhaust, and 12v electrical with a custom wire harness and custom electrical box hiding the battery, fuses and all connections under the seat. I originally restored the bike 2 years ago after it had sat in a barn for over 25 years. I had gotten lots of compliments for a half effort restoration with a real nice paint job, but it just wasn't good enough.
This is the before pic of when I saved it from the barn
And after the first restoration
Then last summer my bike had fallen over in a friend's driveway, doing quite a bit of damage including a large dent in the side of the tank. So that's when I decided to rebuild the bike into a cafe racer. I did all of the work myself except for the custom aluminum seat that Bedlam Werks fabricated specifically for my bike. The fuel tank I pounded in the sides and fronts and then smoothed out with body filler and primer. The paint is gold pearl on top of black base, which ended up giving it a chameleon British Racing Green look. The marbleized stripe is champagne gold. The custom 2-1 exhaust is actually the original dual exhaust that I had cut up and reformed, and then added a 2" collector pipe for better scavenging and high rpms and an Emgo Dunstall replica muffler with the baffle removed. It has a very unique deep throaty tone that barks like an attack dog. The bike is pretty much done now, but there are a couple of loose ends that need to be finished up, like fork gaiters and a windscreen
Feel free to comment and ask questions!
A couple of videos.
http://youtu.be/f0uJiGM8NKg
https://www.youtube.com/watch?v=kSfpy0a ... 5OmZ0BwRVA
#44155
In photobucket, choose your picture,click on the HTML strip by the side, it will change to yellow and say "copied". Open your reply box and right click, then paste. When you see your reply posted, the pic will be showing. You have to click the HTML link.
I found it wouldn't work on my Ipad, as when I clicked on the HTML link, I just got a cursor to type something.
Ray.
Hi Scottie, glad you made it over. Posting on this forum isn't as straightforward as it ought to be.
Not only does posting pictures need a different technique, but to get a paragraph break, which makes the text easier to read, type < b r > (without the spaces) and it
spaces things out for you.
Regards,
