- Tue Feb 10, 2015 4:14 pm
#4653
Started assembly of primary after new sprag clutch fitted. One thing to watch for when tapping engine sprocket back on shaft is that the gear teeth on the starter gears mesh with driven gears on sprocket. Tap sprocket on keeping an eye on the gear teeth behind.
I now have to make up a tool to hold the clutch centre so I can tighten the retaining nut. I didn`t need one to undo it because it wasn`t tight! And no, I don`t have any spare clutch plates to use for one! I do however have lots of bits and bobs of metal strip and sheet in the shed. A legacy of a working lifetime in engineering! Ray.
