- Sun Jan 11, 2015 11:08 pm
#4579
As threatened at the end of Scalyback's post on Christmas Night Riding, I finally let my curiosity get the better of me and ordered a 12V 60/55W rated LED H4 replacement unit for a try out. Not available from our hosts yet but you can get them here:
http://www.dynamoregulatorconversions.c ... s-shop.php
First reaction on opening the box was "That's never going to fit!", as the actress said to the episcopal gentleman. There's quite a chunky deflector on what would be the filament side on a normal bulb, I was concerned this would foul the Neolite's own deflector, but it doesn't. But if you have a Neolite where the deflector has come adrift, this might be a solution.
I say MIGHT, as the unit also has a finned heatsink mounted where the normal H4 bulb's terminals would go. Instead three wires pass through a small black box and on to a terminal block with the standard H4 bulb terminals protruding from it. This is connected to the bulbes female terminals as per normal. Again I was concerned as to whether there was enough room in the headlamp shell, but there was. However, there is a warning on the suppliers web site that these units are not suitable for headlamps shell which contain a speedometer, so I'm afraid that's no go most Bullets running with the standard Casquette headlamp casting. If your bike has the standard Lucas 7" headlamp shell, it will fit.
Does it work? Yes very well, lovely bright light on main and dip, though the bluish white LED colour takes a little getting used to. The Pilot bulb only manages a dirty yellow glimmer by comparison. The good news is that on main beam the unit only draws 1.66 amps, so @ 12v that's a rating of less than 20W for a claimed equivalent to 60W ouput. It works on + or - earth systems, though I don't know if it would work with direct A/C lighting on the '99-on classic models.
PROS: Very bright light, lower power consumption. CONS: expensive (at the moment) compared to traditional H4 bulbs, and too bulky for Casquette headlamp castings. I'll see how this performs over the longer term and how long it lasts, if it fails too soon it will be better to go back to conventional H4 bulbs, though hopefully it will survive for a good while. We shall see (or not).
