By Yorkie
#42560
Retro, the metal plug cap is a restor type,so the plug recommended by our 'HOSTS'BP6ESwil be correct
Hope this helps
Safe Riding
YORKIE
By Thack
#42561
Thanks, papasmurf. Yorkie says it's a resistor cap, so I should be using a BP6ES, whereas I've actually got a BPR6ES in it. So, Retro, I can assure you that a BPR6ES works fine, even if it's theoretically wrong! :-)
By Beezabryan
#42570
Seemingly it ain't broke so why the haste in mending it?
But if you must then why not just replace like for like, it worked before it will work again :)
By Thack
#42576
Now come on, BeezaBryan! You should know that the rules for owning an Enfield include "If it ain't broke, keep fixing it until it is."
By oldjohn1951
#42668
Spark plugs are not created equal. Each manufacturer has its own set of specs. I have had very good luck with Champion spark plugs. I suggest you replace the NGK plug with a new, properly gapped Champion N3C. The thread and reach are identical to your NGK plug. I have used this same plug in my BSA and Triumph from the 1970s and I use another Champion plug today in my Honda. I have no complaints. Also, because of the heat generated at the top end, I give the spark plug thread a coat of the silver anti-seize lubricant. Hope this helps.
By Leon Novello
#42670
Oldjohn is giving good advice, the threads should have a smear of anti-seize on them. Steel and aluminium create an electrolysis causing corrosion. Ask anyone who tried to remove a seized plug and ripped the thread out of the cylinder head.
