- Wed Dec 17, 2014 11:33 am
#42526
Are you getting much power out of the power plant (not sure what a Super Meteor has)
Only, a point is that after 50-60 years, the magnetism will have diminished. All magnets before the recent Neodymium type are not that permanent.
The older 'alinco' type loose their magnetism over years, OR if you remove them from their frame (Break the magnetic circuit), that will decrease their power immediately , by up to 25 % or more.
I have some old three rail Hornby Dublo locos from the fifties, and had them demagnetised. they went from sluggish and power hungry overheating things, to very powerful indeed. The point here is that although there are many problems with rectifiers and regulators and other things, nobody seems to draw attention to the fact that many an old stator will improve dramatically if re magnetised.
This may not be Norm's problem, but still something to bear in mind if your charging is less than specifications.
An associate of mine who collects electric master clocks, remarked that his Magneta generator did not seem to work very well. I mentioned recharging the magnets, and he did the typical bang of the palm of the hand on his forehead. Perfectly logical, but something that even the very knowledgeable often overlook.
Hopefully somebody with more knowledge of magnets and rotors/stators, could add more useful information below? I only have a general knowledge.
REOC 15084
Tabellarius de verbis. Ostensor gaudium
